Hi i had a ASCII string, how do i convert it into binary?
I was told to use bit masking to do it.
thanks in advance
thanks in advance
For Arduino (you can adapt to your need if pure avr):
void setup() {
Serial.begin(9600);
char *str = "0123";
for (char *c = str ; *c ; c++)
for (char b = 7 ; b > -1 ; b--)
Serial.print((*c >> b) & 0x1 ? "1" : "0");
void loop() {
caltex88:
Hi i had a ASCII string, how do i convert it into binary?I was told to use bit masking to do it.
thanks in advance
Is the GPS NMEA data question again?
