Hi all,
I recently bought a new laptop so decided to make a new wiggler that
for USB except I am having some trouble with it. Hopefully someone can help me as I am starting to run out of ideas.
The PCB uses the jtagkey FT2232 pinout except I added
RX/TX pins to the header from channel A. I am using the jtagkey driver that comes with openocd.
I keep getting communication failure, and using an oscilloscope , the reset signals from the FT2232L IC don’t seem to have the right states. (nTRST remains high and its enable
low (enabled), nSRST low and its enable is always high).
TCK and TMS seem to have some signals on them (using 10ms timebase), TDI stays about low, TDO seem to be high.
I am trying to program an AT91SAM7A3 that I know is working at least
because it currently has usb code in it which enumerates when i plug it
into a pc. The problem appears to be that signals are not coming out of
the ft2232 properly.
I get the following output from R204 openocd:
Info: openocd.c:93 main(): Open On-Chip Debugger (2007-09-05 09:00
CEST)
Debug: jtag.c:1407 jtag_init(): -
Debug: ft2232.c:1296 ft2232_init_ftd2xx(): ‘ft2232’ interface using
FTD2XX with ‘jtagkey’ layout (0403:cff8)
Debug: ft2232.c:1385 ft2232_init_ftd2xx(): current latency timer: 2
Debug: ft2232.c:1651 jtagkey_init(): 80 08 1b
Debug: ft2232.c:1709 jtagkey_init(): 82 09 0f
Debug: ft2232.c:253 ft2232_speed(): 86 00 00
Debug: jtag.c:295 jtag_call_event_callbacks(): jtag event: TRST
asserted
Debug: jtag.c:1197 jtag_reset_callback(): -
asserted
Error: jtag.c:1253 jtag_examine_chain(): JTAG communication failure,
check connection, JTAG interface, target power etc.
Error: jtag.c:1440 jtag_init(): trying to validate configured JTAG
chain anyway…
asserted
Error: jtag.c:1346 jtag_validate_chain(): Error validating JTAG scan
chain, IR mismatch, scan returned 0x3f
asserted
asserted
asserted
asserted
asserted
Error: jtag.c:1448 jtag_init(): Could not validate JTAG chain, exit
and my script is:
telnet_port 4444
gdb_port 3333
#interface
interface ft2232
ft2232_device_desc “Amontec JTAGKey A”
ft2232_layout “jtagkey”
ft2232_vid_pid 0x0403 0xcff8
jtag_speed 100
jtag_nsrst_delay 2000
jtag_ntrst_delay 2000
#use combined on interfaces or targets that can’t set TRST/SRST
separately
reset_config srst_only srst_pulls_trst
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
#target configuration
daemon_startup reset
#target
#target arm7tdmi
target arm7tdmi little run_and_init 0 arm7tdmi
run_and_halt_time 0 30
flash-options AT91
target_script 0 reset openocd_at91sam7a3_flash.script
working_area 0 0x00200000 0x4000 nobackup
flash bank at91sam7 0 0 0 0 0
I’ve tried a lot of changes in the script, and even tried some other
drivers, and openocd R141, but still get the same communication failure.
Has anyone made a FT2232 wiggler that can help me as I am starting to
run out of ideas?
