Hello
Are there any examples for DA16200 monitoring ADC values?
I want to transmit an ADC value using the DA16200 WIFI module. I’m using sparkfun red board and the DA16200 WIFI shield.
Best Regards,
DP
Hello
Best Regards,
DP
This https://learn.sparkfun.com/tutorials/ge … io-control might be what you’re after - just assign & read a GPIO as an analog input pin
It also might help to start at the beginning of the larger tutorial to ensure your software stack matches
Thank you.
Is there a SoftwareSerial.h for Sparkfun Redboard Turbo? It doesn’t seem to auto install similar to the regular Redboard.
Best Regards,
DP
Try this one https://github.com/paulvha/SAMD21/tree/ … wareSerial
