It worked normally for me; ensure you have SparkFun ESP32 MicroMod as the board selection and correct port
Also, try the SparkFun esp32 MicroMod → SD(esp32) → SD_Test sketch instead of the default espressif one
Then compare the code to the Espressif one (if needed) and adjust the pin #'s to match…or modify the sparkfun one ![]()
