I’m desperately in need of a datasheet for Sparkfun GPS-14986 (https://www.sparkfun.com/products/14986). The previous version, GPS-00464, has a datasheet. I’m trying to design in this replacement, and I need a datasheet to approve.
One thing I’m specifically looking for is the operational temp spec. Previous version shows -40°C - +85°C. Is this new replacement the same?
Hello mjschuetz.
Unfortunately we do not have a data sheet for this part and I’m unable to confirm the temperature range. The specs are probably similar to the earlier version but sadly I can not find any documentation for the antenna.
Is there any way you can contact the manufacturer to see if they can provide a datasheet? Is On Shine making this one as well, or is it a different company now?
I’ve put in a request for a data sheet for you but I don’t know for sure when (or if) I will be able to get one. I’ll update this thread if I am able to get one though.
Thank you! Appreciate the help.
Great news mjschuetz, I was able to get a data sheet!
Hope this is helpful, and have a great weekend.
GPS-14986 Data Sheet.pdf (336 KB)
