HELP!
I was writing a sketch to try interrupts (first time using interrupts) and uploaded the following code to my Pro Micro:
    int SwitchPin = 3;
    ISR(INT0_vect)
      Serial.println("INTERRUPT");
    // the setup routine runs once when you press reset:
    void setup()
      Serial.begin(9600);
      bitSet(SREG,7);       // enable Global Interrupts
      bitClear(EICRA,7);
      bitSet(EICRA,6);
      bitSet(EIMSK,0);
    // the loop routine runs over and over again forever:
    void loop()
Now when a USB cable is plugged into the Pro Micro Windows reports “USB Device Not Recognized”.
I have tried using an UNO as an ISP but avrdude reports “Yikes! Invalid device signature” (not sure if this is a result of the sketch or something else I am doing wrong)
Any suggestions on how to restore it? Or is my poor little Pro Micro dead?
