Hey.
Im trying to make this sim reader.
https://www.ladyada.net/make/simreader/ … erv1_0.png
https://www.ladyada.net/make/simreader/make.html
It uses a 9v battery. the ST78M05 steps it down to 5v, verified by multimeter.
I am adding an sp3232ebcn-L/TR to eventually connect it to my rpi4b.
Datasheet:https://assets.maxlinear.com/web/docume … 3232eb.pdf
I hooked up all the charge capacitors in the appropriate locations, according to this: https://www.sparkfun.com/products/11189 … gIWfvD_BwE
If i did it right, i hooked up the 5vcc line to pin 2 of the sp3232 chip. (V+)
R1 and T1 lines read 3.3v.
My questions:
pin 16 is reading 3.3v. Should it? So, i should connect a jumper from the rpi 3.3 rail to pin 16 of the sp3232, right?
pin 15 of the sp3232 is ground. Is this a separate ground? Or do i link it together with the sim reader’s circuit ground, which is connected to the 9v battery?
the rpi has its own ground. Should i link this ground with it all?
Do i reverse the TX/RX lines in the circuit at any point? How about at the final point when connecting to the rpi.
I didnt think i should.
I was reading about ground looping. I dont want to fry my rpi.
Thanks for reading.
