timgray:
WHY is the drillfile scaled by 10?? or is there a bug in viewmate when importing the drillfile and it’s simply leading me to believe it is wrong?
ViewMate defaults to 3.4 format. Before you "Import" the drill file, click on "Options" and change the Data Format. You want Left of decimal: 2, Right of decimal: 3 and select Omit leading zeros. Click on "OK" then click on "Import".
I am a newbie and I am i trying to import my files into ViewMate. The Drill file works fine. However the other files do not. I believe their origin is not at (0,0). How would I set the origin in Eagle? How would I set the origin in ViewMate since this could also be the problem? Or does someone know another way I could have screwed up?
I’m desperately searching for that documentation because I’m building an small cnc and I want to convert those execellon files to gcode’s (the driving program doesn’t know excellon standard).
