Drill rules --
Hello – I know that BatchPCB does not offer unplated drill holes – however I’m trying to find something close.
I am trying to get a pad as close as possible to the drilled hole – my question is am I required to have a copper ring on the top and bottom layers of copper around the drill hole?
I’ve drawn a picture if that helps visualize it
Thanks for the help.
You do not need a ring if you make the hole a mounting hole.
