trying to setup Eclipse+OpenOCD as per Lynches tutorial.
Launching OpenOCD is fine; can telnet from the terminal to port 4444 and get a connection and can issue commands. Also telnetting to gdb port 3333 works, although I’m unsure what commands it takes.
From Eclipse can start OpenOCD, it resets my board, but when I start the blink app, OpenOCD complains as follows:
Info: server.c:67 add_connection(): accepted 'telnet' connection from 0
Info: server.c:367 server_loop(): dropped 'telnet' connection
When I try again it says:
Error: telnet_server.c:173 telnet_input(): error during read: Connection reset by peer
In Eclipse the blink code is suspended and can’t get it to run, possibly because it can’t get a debug connection?
Anyone has suggestions on this issue?
Arthur
