I’ve a little problem when I want to dump the nand memory on my board :
cpu : s3c2410A nand : k9f1208uom (64MB).
When I enter the command “nand probe 0” the following error occur : “Address translation failure”
and the following memory is found “NAND flash device ‘NAND 64MiB 3,3V 8-bit’ found”.
Well, It’s good.
But when I want to read the nand memory the error message is displayed “Address translation failure”
and the read speed is very slow : 4096 bytes in 9 seconds.
Have you an idea ?
Thank a lot,
Yves Teissier
