I had to rotate some parts in the PCB, now half my caps have the name on the bottom and the other half on top. How can a force the name to be on top regardless of orientation?
A global fix would be appreciated.
Thank you.
GSM_C1
.22pF
10uF
MCU_C3
Select SMASH from the EDIT menu, and click on each part. This separates the label placement from the part placement. Then select MOVE, click on the cross-hair of the label and it can be moved to the position you want. Right-clicking will rotate the label.
There is a ULP on Eagle’s website to “smash all” to make moving labels a little easier.
