Hey guys,
Anyone has such a library? It’s not present in the default Eagle library nor in the Sparkfun library.
Thanks in advance,
Laci
Hey guys,
Thanks in advance,
Laci
mondalaci:
Hey guys,Anyone has such a library? It’s not present in the default Eagle library nor in the Sparkfun library.
Thanks in advance,
Laci
Look at AVR_SPI_PRG_6 under sparkfun library. If that’s not what you need, could you please add a picture or something so i can understand exactly what you are looking for?
Create your own part, or modify a similar existing part. It should only take a couple of minutes.
Look for ML6 in the con-harting-ml or the con-ml libraries.
leon_heller:
Do you type that out every time or have it saved somewhere? ![]()
It’s worth repeating each time. I just don’t understand why people bother to ask for something like that, they are either lazy or stupid!
I agree with Leon in this case. Learn how to build your own parts - it’s pretty simple! And don’t assume parts out of any Eagle library are correct without checking.
