I downloaded “Eagle Footprint” of nokia lcd connector Eagle library to make a pcb with it for my Arduino project.
The problem is that I’m also new to Eagle and can’t connect the wire in Schematic to extend the connectors pins and you can see the problem in the image. Eagle forces a defined gap between wires and I don’t know where the setting is.
Could anybody please tell me how I can tune Eagle so that to directly connect wire to the connector pins please?
In addition to the previous comments, this won’t end well if your traces are on the bottom layer while your component is on the top layer. Using a schematic and airwires would have prevented that error.
macegr:
