EAGLECAD help requested
good evening all and happy holidays…
I am using eaglecad v5.10 and have created an AVGO HFBR2412 which I could not find on the web.
I did pretty good except it shows a warning saying “NET 5V OVERLAPS PIN” and when you run the autorouter… it does not show any wires connected to the new components.
I have not seen this error before and find nothing in any of my documents about it. Can anyone help?
thanks in advance
Dillon
Would you be able to upload a zip of .lbr, .brd, and .sch files that have this problem?
EDIT: And correct me if I’m wrong, this is a problem with a library part you made? If so, make sure the pins on the schematic symbol have the circles on the outside, because that is the end you make connections to.
