Is it possible to debug an at91sam7s256 using only a wiggler and arm-elf-gdb debugger? I am able to debug a simple program in ram, but I am not able to do the same in flash. I am also able to transfer a *.bin program on chip flash via Atmel ISP.
Here are the commands I use for the debugger in Eclipse
target remote localhost:3333
monitor soft_reset_halt
monitor arm7_9 force_hw_bkpts enable
symbol-file main.out
thbreak main
load
continue
Is there something wrong?
Or it is physically impossible using only a wiggler to debug in flash?
thank you all for your support
