Eclipse warning "Error launching external scanner info
It seems there are Eclipse experts here , so I would like to ask
a question regarding a problem I can not fix.
I “googled” a lot and I found some hints but not really a solution .
The problem is, I have two Eclipes+GNUARM installations running.
Thanks to Jim P. Lynch perfect documenation. However, one works but
the other shows the warning :
“Error launching external scanner info generator (gcc …/specs.c)”
if I open a project.
I installed just two times the same stuff.
I know that the path for gcc and make is set correctly, I can start
gcc and make from the console. I think there is nothing missing and
all seems to be accessible.
Nevertheless I’m getting the warning described above.
Any idea what is wrong ?
Thank you
I found how to fix it!
I do not know why but after I installed the latest version of
Suns Java J2SE Runtime Environment 5.0
it works on all machines the same way.
cioa
