EM-402 External Antenna Question
Reading the datasheet (http://www.sparkfun.com/datasheets/GPS/ … 0Specs.pdf) for this module, I can’t find a couple of pieces of info that I’d like:
  1. The unit supports an external antenna. How does one switch between the two antennas? Can it be done in software (eg can I install it as-is, route the external connection outside of my project, and still switch antennas?).
  2. Does anyone have dimensions on the integrated antenna (specifically the thickness, including the backplane)?
Forget #2. I just saw the picture (http://www.sparkfun.com/commerce/images … l_i_ma.jpg).
