EM-506N5 failing to indicate a lock
I have an [EM-506N5, it’s [datasheet says the LED will start blinking once it has a lock. I have been sitting on the patio with this powered for almost an hour and the LED is still solid. I’m also not getting any data from SoftwareSerial.h through an Arduino. Is this unit broken? I’m not sure how to start debugging this.](https://cdn.sparkfun.com/assets/e/5/e/8/2/Data_Sheet_EM-506N5.pdf)](GNSS Receiver - EM-506N5 - GPS-19629 - SparkFun Electronics)
Double-check the wiring vs pg 2 in that datasheet; also ensure it’s Vin has proper voltage (looks like 4.5-6.5v) and the IO voltages match (TTL, 0-3.3v)
Is their a clear view of the sky (no cloud cover, etc)?
