Embedded scripting engine
I’m looking for a small scripting engine implementation for my
embedded project running on STM32F103T6 MCU @ 72MHz and FreeRTOS 6.0.4
and ST library 3.2.0.
Right now, I’m using a derivate of basic language with code:
c=0
for d=1 to 10000
set_onboard_led c
if c=0 then c=1 else c=0
next d
end
and get performance roughly 1 millisecond per 1 loop. The project is
level 2 optimized in GCC (-O2).
The script is running as an operating system task. I’m looking for an
alternative scripting solution that can do roughly 20 microseconds per
1 loop.
Thanks in advance!
eLua.
http://www.eluaproject.net/
I dunno if it fits on your part, it runs on the 512kb parts. I have run it on a 512Kb Cortex M3 device. Still needs some interfaces for hw, OR you can use SWIG to generate interfaces to your C code to hw.
Other tools to look at:
microLua. an even smaller lua that runs on NintendoDS.
http://code.google.com/p/microlua/wiki/MicroLua
Tcl. the base tcl compiles to a pretty small app IIRC, I built it once for a PowerPC405 chip.
Doing a little search may rule this one out, I recall I already had a cross compiler, so building it was easy. Standard tcl stuff.
S-lang. its been ages since I worked with this, but think C scripting, it was also very small.
http://www.s-lang.org/
Forth. forth was famous for going onto really small hw parts.
One example I found: http://eddiem.com/micros/sam7forth/armforth.html
Let me know what you decide on and how well it works…
Although it is unlikely to meet your ambitious performance requirements, I recommend you have a look at Bitlash, which you will find at http://bitlash.net
The version I distribute on bitlash.net is in C for Arduino, but it is not a big deal to port to other C architectures and I would welcome and support such a contribution :wink:
Happy to answer questions here.
-br
http://bitlash.net
http://entropymouse.com
