Hi there,
Can you suggest some good embedded web servers?
I need to make some measurements of some sensor and transmit the reading over internet (TCP/IP) to a computer.
The microcontroller of the embedded server should be 8 bit AVR.
The C codes should be available so that I can modify it for my own use.
The C codes should be compilable on WinAVR software.
There should be sufficient instructions and examples on how to use the server and the C codes for it.
Any suggestion and recommendation?
