Can you guys help the bug from the code? I can’t run from Arduino IDE.
Read both CCS811 and BME280 sensors at same time
By: Nathan Seidle
SparkFun Electronics
Date: April 6th, 2017
License: This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
Works with SparkFun combo board https://www.sparkfun.com/products/14241
Enjoy this code? Buy a board and help support SparkFun!
Let’s read both sensors at the same time!
Outputs CO2, TVOC, temperature, humidty, and pressure.
Hardware Connections (Breakoutboard to Arduino):
Attach a Qwiic Shield to your RedBoard, Photon, or ESP32.
Plug the Qwiic Air Quality Combo board into one of the connectors
Serial.print it out at 9600 baud to serial monitor.
#include <Wire.h>
#include “SparkFunBME280.h” //Library for BME280 from library manager or https://github.com/sparkfun/SparkFun_BM … no_Library
#include “SparkFunCCS811.h”
#define CCS811_ADDR 0x5B
CCS811 myCCS811(CCS811_ADDR);
BME280 myBME280; //Global sensor object for BME280
//Global variables obtained from the two sensors
unsigned int tVOC = 0;
unsigned int CO2 = 0;
float tempf = 0;
float humidity = 0;
float pressureInHg = 0;
void setup()
Serial.begin(9600);
Serial.println(“CCS811+BME280 Read Example”);
Wire.begin();//initialize I2C bus
CCS811Core::status returnCode = myCCS811.begin();
if (returnCode != CCS811Core::SENSOR_SUCCESS)
Serial.println(“Problem with CCS811”);
printDriverError(returnCode);
else
Serial.println(“CCS811 online”);
//Setup the BME280 for basic readings
myBME280.settings.commInterface = I2C_MODE;
myBME280.settings.I2CAddress = 0x77;
myBME280.settings.runMode = 3; // 3, Normal mode
myBME280.settings.tStandby = 0; // 0, 0.5ms
myBME280.settings.filter = 0; // 0, filter off
myBME280.settings.tempOverSample = 1;
myBME280.settings.pressOverSample = 1;
myBME280.settings.humidOverSample = 1;
delay(10); //Give BME280 time to come on
//Calling .begin() causes the settings to be loaded
byte id = myBME280.begin(); //Returns ID of 0x60 if successful
if (id != 0x60)
Serial.println(“Problem with BME280”);
else
Serial.println(“BME280 online”);
void loop()
if (myCCS811.dataAvailable()) //Check to see if CCS811 has new data (it’s the slowest sensor)
myCCS811.readAlgorithmResults(); //Read latest from CCS811 and update tVOC and CO2 variables
//getWeather(); //Get latest humidity/pressure/temp data from BME280
printData(); //Pretty print all the data
else if (myCCS811.checkForStatusError()) //Check to see if CCS811 has thrown an error
Serial.println(myCCS811.getErrorRegister()); //Prints whatever CSS811 error flags are detected
delay(2000); //Wait for next reading
//Print CO2, TVOC, Humidity, Pressure and Temp
void printData()
Serial.print(" CO2[");
Serial.print(myCCS811.getCO2());
Serial.print(“]ppm”);
Serial.print(" TVOC[");
Serial.print(myCCS811.getTVOC());
Serial.print(“]ppb”);
Serial.print(" temp[");
Serial.print(myBME280.readTempC(), 1);
Serial.print(“]C”);
//Serial.print(" temp[");
//Serial.print(myBME280.readTempF(), 1);
//Serial.print(“]F”);
Serial.print(" pressure[");
Serial.print(myBME280.readFloatPressure(), 2);
Serial.print(“]Pa”);
//Serial.print(" pressure[");
//Serial.print((myBME280.readFloatPressure() * 0.0002953), 2);
//Serial.print(“]InHg”);
//Serial.print(“altitude[”);
//Serial.print(myBME280.readFloatAltitudeMeters(), 2);
//Serial.print(“]m”);
//Serial.print(myBME280.readFloatAltitudeFeet(), 2);
//Serial.print(“]ft”);
Serial.print(" humidity[");
Serial.print(myBME280.readFloatHumidity(), 0);
Serial.print(“]%”);
Serial.println();
void printDriverError( CCS811Core::status errorCode )
switch ( errorCode )
case CCS811Core::SENSOR_SUCCESS:
Serial.print(“SUCCESS”);
break;
case CCS811Core::SENSOR_ID_ERROR:
Serial.print(“ID_ERROR”);
break;
case CCS811Core::SENSOR_I2C_ERROR:
Serial.print(“I2C_ERROR”);
break;
case CCS811Core::SENSOR_INTERNAL_ERROR:
Serial.print(“INTERNAL_ERROR”);
break;
case CCS811Core::SENSOR_GENERIC_ERROR:
Serial.print(“GENERIC_ERROR”);
break;
default:
Serial.print(“Unspecified error.”);
