Using the Arduino IDE (version 1.8.13 for the Mac, though that doesn’t seem to matter), if I select the SparkFun RedBoard Turbo and try to compile example sketches from the “Adafruit_EPD” library (“text_test.ino” for example), the compiler chokes. This message, pruned from the compiler log, looks relevant:
…/Documents/Arduino/libraries/Adafruit_EPD/src/Adafruit_EPD.cpp:533: undefined reference to `Serial’
Another possible clue is that the same sketch compiles ok if any of these other SparkFun SAMD boards are selected:
SparkFun Qwiic Micro
SparkFun SAMD51 Thing Plus
SparkFun SAMD21 Pro RF 1W
SparkFun 9DoF Razor IMU M0
SparkFun SAMD21 Mini Breakout
SparkFun SAMD21 Dev Breakout
I don’t know if this problem is with the Adafruit_EPD library, the SparkFun RedBoard Turbo definitions or a combination thereof. Could you look into this and, if necessary and/or possible, coordinate with your colleagues at Adafruit?
