Error Loading Sparkfun Libraries
Been a while since I used Eagle(6 months), but when I try to load Sparkfun libraries from the Eagle control panel, I get the following error:
line 5, column 6: This is not an EAGLE file.
I downloaded from Sparkfun : https://github.com/sparkfun/SparkFun-Eagle-Libraries
I have examined the files with Geamy and nothing obvious jumps out.
I’ve tried loading with Eagle 6.2, 6.3 & 6.4 with same results.
Gotta be something obvious I’m missing. Didn’t find anything searching forums.
Thanks in arvance,
rbarnich
Found the problem. Downloaded HTML file, not the .zip
