in /home/user/freedom-e-sdk I type the following the commands
mkdir -p work/build/openocd/
cd /home/user/freedom-e-sdk/openocd
autoreconf -i
cd /home/user/freedom-e-sdk/work/build/openocd/
/home/user/freedom-e-sdk/openocd/configure --enable-jtag_vpi --prefix=/home/user/freedom-e-sdk/work/build/openocd/prefix --disable-werror
make
The above commands do work. However when I switch to cross compiling I use the commands below
/home/user/freedom-e-sdk/openocd/configure --prefix=/home/user/freedom-e-sdk/work/build/openocd/prefix --disable-werror --host=x86_64-w64-mingw32
make
I get the following errors:
In file included from /home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c:21:0:
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.h:23:72: warning: ‘struct usb_dev_handle’ declared inside parameter list
int jtag_usb_open(const uint16_t vids, const uint16_t pids, struct usb_dev_handle **out);
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.h:23:72: warning: its scope is only this definition or declaration, which is probably not what you want
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c:25:3: warning: ‘struct usb_device’ declared inside parameter list
const uint16_t vids, const uint16_t pids){
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c: In function ‘jtag_usb_match’:
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c:27:10: error: dereferencing pointer to incomplete type ‘struct usb_device’
if (dev->descriptor.idVendor == vids &&
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c: At top level:
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c:35:10: warning: ‘struct usb_dev_handle’ declared inside parameter list
struct usb_dev_handle **out){
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c:34:5: error: conflicting types for ‘jtag_usb_open’
int jtag_usb_open(const uint16_t vids[], const uint16_t pids[],
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.h:23:5: note: previous declaration of ‘jtag_usb_open’ was here
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c: In function ‘jtag_usb_open’:
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c:36:2: warning: implicit declaration of function ‘usb_find_busses’ [-Wimplicit-function-declaration]
usb_find_busses();
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c:37:2: warning: implicit declaration of function ‘usb_find_devices’ [-Wimplicit-function-declaration]
usb_find_devices();
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c:39:27: warning: implicit declaration of function ‘usb_get_busses’ [-Wimplicit-function-declaration]
struct usb_bus *busses = usb_get_busses();
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c:39:27: warning: initialization makes pointer from integer without a cast [-Wint-conversion]
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c:40:51: error: dereferencing pointer to incomplete type ‘struct usb_bus’
for (struct usb_bus *bus = busses; bus; bus = bus->next) {
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c:41:3: error: ‘struct usb_device’ declared in ‘for’ loop initial declaration
for (struct usb_device *dev = bus->devices; dev; dev = dev->next) {
/home/user/freedom-e-sdk/openocd/src/jtag/drivers/usb_common.c:41:61: error: dereferencing pointer to incomplete type ‘struct usb_device’
I am not sure what’s the problem with the file usb_common.c, since it works when I compile for ubuntu.
