ESP32 Micromod + PoE-Ethernet = no boot. invalid header 0xffffffff
“Not much you can do except for cutting a trace on the ESP32MM, the MM motherboard OR Ethernet MM. Easier, best workaround is using double MM mother board.”
  1. double is not an option (very limited space) - what and where exactly do I have to “cut” on the board?
  2. I find it strange that this issue exists at all, doesn’t that mean that every customer with that config would run into that? It sounds like something Sparkfun should take a closer look or provide info in the hookup guide if its just a matter of cutting a trace?
