MicroMod STM32 Processor and Single Pair Ethernet Function Board don't work together
The hardware combination is as follows: MicroMod STM32 Processor, MicroMod Main Board, Single Pair Ethernet Function Board.
After flashing the code according to the MicroMod STM32 Processor Hookup Guide, the serial port only prints the first line “Single Pair Ethernet - Example 1b Basic Echo”. Then it won’t continue to run.
I debugged step by step and found that the code stopped running “adin1110_Init(hDevice, pCfg);”
Is the routine code suitable for stm32f4? If so, what is the problem?
There’s a customer comment making me think it might not have ETH pin broken out? https://www.sparkfun.com/products/21326
You can create an issue here https://github.com/sparkfun/MicroMod_ST … sor/issues to alert the engineering team…though I don’t think that will immediately get something working for you…if purchased from Sparkfun.com, head to www.sparkfun.com/returns and we can swap the STM for a different processor
If purchased elsewhere contact vendor for similar
