Hi All ., was wondering if you could help a newbie out.
I am using Esp32 Thing C wroom with 4 ws8212 addressable led strips from Adafruit each with 300 leds on so 1200 leds in total.
I am using Wled code and app to control them , but i am gonna need an external powersupply for the 4 strips and was wondering if my idea of hooking it up will work.
Please consider that i am a TOTAL newbie in this , today is my first day messing with a board of this kind.
But my theory would be Taking +v directly to ledstrip , data to GPIO channel and Gnd to both Gnd on board and strip ?
would i be right in doing that ?
So many thanks in advance.,
Ice1505
Yep (using the Thing C WROOM pin #s with Wled)
Check out pgs 9-> http://cdn.sparkfun.com/datasheets/Comp … rguide.pdf to see a general guide on how it all works
Thx man , really appreciate that
TS-Russell:
Hi again TS Russell
Can i bother you a bit more
i have got the board working with 1 led strip using VUSB , GND , 4/free as channel… now im curious to the different GPIO , can i use any GPIO as control channel for the digital signal going to a ws2812 strip or are there some reserved for board function
Also if some are reserved which can i safely use for controlling my signal
and how many can i use if using external pwr supply :?:
Hope im not bothering to much with all my questions
Yes, different GPIO pins will work…just declare the new # in code
The PWM signal is sent over GPIO with a channel #0-15 selected; see here for more info https://www.electronicshub.org/esp32-pwm-tutorial/
