ETA on PSP Carrier Board
Do you know if there is another place that has a similar product.
If this is at all helpful, I recently made a couple crude adapters to run the pinout through a breadboard for some projects I have wanted to try with this LCD. I used a similar construction method to what busonerd was suggesting on the previous page, with some salvaged connectors, radioshack perfboard, 40 pin headers, and 30 awg wire.
//broken photo links removed
just wow :shock:
FYI:
I have been making a PSP LCD/touchscreen adapter board as well (although it has a bunch more peripherals). I call it RMT1. It will be available for sale in 2-3 weeks.
It is intended to be a peripheral board for the Atmel NGW100 AVR32 board. The interface is just a set of 0.1" headers, so RMT1 should be adaptable to other CPU boards, etc.
It also has footprints for the VirtualCogs VCMX21, although I have pretty much given up on supporting it.
You can see the history of development on my blog:
http://apps.mediamatech.com/Blog/
And the DRAFT revision of the User Manual outlines at length what it will have and not have:
http://www.mediamatech.com/shop/downloa … T1_v01.pdf
I have also created source patches and binaries for u-boot and linux kernel for AVR32, specifically for the NGW100 and RMT1 peripherals (including LCD and touchscreen).
Regards,
Pete
I am a beginner at this stuff. Where should I start?
rickyman:
Is there something specific you would like to do? A project you want to try? Or an idea you want to figure a way to bring to reality? A specific technology you want to dig in and learn about?
If you can answer one or more of those questions, then I think you can find all sorts of help around here.
Regards,
Pete
In my end result, I want to be able to run Linux on an embedded system. I want to use the touch screen and the psp screen, and along with other add-ons like accelerometer.
rickyman:
I would suggest you start a new topic in another Sparkfun forum, like “Projects”.
viewforum.php?f=14&sid=01beb481f3872ce184a84d57ba029666
The more details you provide, and your level of experience/knowledge, would be helpful, so you can get relevant responses from others.
