We have a requirement of making Ethernet video in mp4 or 3gpp format to be compatible to be displayed on a tv with input of NTSC or PAL. What kind of Ethernet controller is needed to handle the video streaming which can have a I2C serial communication with a micro controller? Does it require a stack? or can it be used directly? Can Audrino Ethernet shield be used with a video decoder or encoder for the process?
You could go with a processor and video chip but then you would need to know how there are connected, then design a PCB then write all the code. If you can do all that then go for it.
The R-Pi runs Linux and there are examples of doing this. Check the R-Pi tutorials on Adafruit’s web site for starting.
There is the XBMC code for the R-Pi also. Maybe this would work.
Did you check into the Roku box? A possible cheap off the shelf solution.
waltr:
i did check roku box, only roku 3 is with ethernet but it doesn’t support all tvs which run on ntsc or pal.
