File writed in the flash BUT NOT in the interrupt vector
Hi, i want to load a file ihex in the LPC2136. I use amontec jtagkey with openocd ver 0.1.0
my script is:
#interface
interface ft2232
ft2232_device_desc “Amontec JTAGkey A”
ft2232_layout jtagkey
ft2232_vid_pid 0x0403 0xcff8
telnet_port 4444
jtag_speed 5
#lpc2136
if { [info exists CHIPNAME] } {
set _CHIPNAME $CHIPNAME
} else {
set _CHIPNAME lpc2136
if { [info exists ENDIAN] } {
set _ENDIAN $ENDIAN
} else {
set _ENDIAN little
if { [info exists CPUTAPID ] } {
set _CPUTAPID $CPUTAPID
} else {
force an error till we get a good number
set _CPUTAPID 0x4F1F0F0F
#delays on reset lines
jtag_nsrst_delay 200
jtag_ntrst_delay 200
#use combined on interfaces or targets that can’t set TRST/SRST separately
reset_config trst_and_srst srst_pulls_trst
#jtag scan chain
jtag newtap $_CHIPNAME cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
set _TARGETNAME [format “%s.cpu” $_CHIPNAME]
target create $_TARGETNAME arm7tdmi -endian $_ENDIAN -chain-position $_TARGETNAME -variant arm7tdmi-s_r4
$_TARGETNAME configure -work-area-virt 0 -work-area-phys 0x40000000 -work-area-size 0x4000 -work-area-backup 0
$_TARGETNAME configure -event reset-init {
Force target into ARM state
soft_reset_halt
#do not remap 0x0000-0x0020 to anything but the flash
mwb 0xE01FC040 0x01
#flash bank lpc2000 0 0 <target#>
flash bank lpc2000 0x0 0x40000 0 0 0 lpc2000_v2 12000
The commands are:
openocd -f openocd.cfg -c init -c halt
flash protect 0 0 14 off
flash write_image erase file.hex 0 ihex
All data are write in the flash BUT NOT in the interrupt vector!
Why? Where is my error?
Ok, now work correctly.
The value of the register MEMMAP should be 0x01.
This cfg work for LPC2136.
The command “cmd_program” is only for file raw-binary.
Bye
#interface
interface ft2232
telnet_port 4444
jtag_speed 5
#lpc2136
} else {
set _ENDIAN $ENDIAN
} else {
set _ENDIAN little
} else {
proc init_proc {} {
debug_level 0
fast disable
jtag_speed 100
jtag_khz 100
reset run
sleep 100
reset halt
wait_halt 2
PLL disconnect PLLCON
mww 0xE01FC080 0x01
mww 0xE01FC08C 0xAA
mww 0xE01FC08C 0x55
PLL disable PLLCON
mww 0xE01FC080 0x00
mww 0xE01FC08C 0xAA
mww 0xE01FC08C 0x55
no prescaler CCLKCFG
mww 0xE01FC104 0x00
internal RC CLKSRCSEL
mww 0xE01FC10C 0x00
main oscil. CLKSRCSEL
mww 0xE01FC10C 0x01
remap to internal flash
mww 0xE01FC040 0x01
sleep 100
jtag_khz 500
flash probe 0
sleep 100
proc cmd_program {IMGFILE} {
halt
init_proc
flash write_image erase $IMGFILE 0 bin
sleep 100
verify_image $IMGFILE 0
sleep 100
NOTE!!! LPCs need reset pulled while RTCK is low. 0 to activate
JTAG, power-on reset is not enough, i.e. you need to perform a
reset before being able to talk to the LPC2148, attach is not
possible.
#jtag scan chain
soft_reset_halt
mwb 0xE01FC040 0x01
flash bank lpc2000 0x0 0x40000 0 0 0 lpc2000_v2 14765 calc_checksum
