https://www.sparkfun.com/products/11520
For this item, is there still an issue with the battery charging circuit? I’ve read that the usb power supplies 5V directly to the 3.7 battery socket.
My application requires the user to plug in the USB to charge the battery and then when sufficiently charged (most likely left to charge unattended for however-long), the user will take the device and run on battery power.
The documentation I read stated that the cutting SJ2 jumper will alleviate the 5V put to the battery, but will render the board dependent on battery power…which i would be fine with as long as the USB port still charges the battery.
I have a 6600mah 3.7v lipo battery in mind and would like to know what to expect. The schematic states only to cut if powering with more than 5.5V…so is it safe to charge a 3.7v battery in this manner?
