to exclude any bootloader problems in my quest to run the Fio v3 (I bought it to save me some time…), I set out to reflash it. Though after a couple of hours, I’m still not there.
I’m using an AVR Dragon for programming, yet I can’t even read the device ID with AVR Studio. Trying with avrdude, it tells me that both ISP and debugWire connect fails.
The Dragon is correctly connected to the Fio v3 ISP pins. The Fio v3 is additionally connected to a USB port (as the AVR Dragon doesn’t deliver power over the ISP header).
I wouldn’t expect that anything else is necessary to read the device ID or the fuses state.
I’d be happy about any hints regarding the reason of this behaviour. Do you guys at Sparkfun know the state of the SPIEN fuse when the device is delivered? How are you programming these devices? HV or ISP?
/M
Dammit. The AVR Dragon doesn’t pull the RST line down. As soon as I do this manually, avrdude works.
So if you’re ever inclined to flash your Fio v3 (or ProMicro) bootloader with an AVR Dragon, first get an alligator clip to tie RST to GND, then issue:
avrdude -P usb -c dragon_isp -p m32u4 -U flash:w:Caterina-fiov3.hex
The board will come up with the new bootloader (yellow LED is slowly fading in and out), the device will have a VID/PID of 1B4F:F100.
mkroll
August 6, 2013, 10:44pm
4
I tried to reflash my FIO v3 as well given the procedure you described:
Resulting my FIOs CHG LED is slowly fading in and out ant the TX and RX LED are on.
The fade in/out never stops…
Any ideas how to reactivate my FIO V3?
Michael.
What do you mean by reactivating it?
What happens when you’re replugging the USB connection now? The device should be recognized by your system and attach to a different driver (given the fact that you’re using Windows). Of course you should have the latest driver available on your system.
Cheers,
/Ma
mkroll
August 7, 2013, 1:08pm
6
By reactivating I mean that I can upload sketches over USB again.
Im running Arduino 1.0.5 on MacOSX. I created an FIO v3 clone, where I wanted to flash the bootloader provided by Sparkfun as part of the additional files distribution available on github: https://github.com/sparkfun/SF32u4_boards.git
Since this is not working, I wanted to test the bootloader installation on the original hardware but the result is identical to the behavior on my Fio v3 clone.
The CHG led is slowly fading in and out, the TX and RX LED are lit 100%. The fading of the CHG LED it running indefinetly. I tried to reflash the bootloader using the IDE with the following result:
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cstk500v2 -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xfe:m -Uhfuse:w:0xd8:m -Ulfuse:w:0xff:m
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/michaelkroll/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200066311
avrdude: usbdev_open(): using read endpoint 0x82
avrdude: Sent: . [01]
avrdude: Recv: . [01] . [00] . [0a] A [41] V [56] R [52] I [49] S [53] P [50] _ [5f] M [4d] K [4b] 2 [32]
avrdude: stk500v2_getsync(): found AVRISP mkII programmer
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 1024 8 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel STK500 Version 2.x firmware
Programmer Model: AVRISP mkII
avrdude: Sent: . [03] . [90]
avrdude: Recv: . [03] . [00] . [01]
avrdude: Sent: . [03] . [91]
avrdude: Sent: . [03] . [92]
avrdude: Recv: . [03] . [00] . [0e]
Hardware Version: 1
Firmware Version Master : 1.14
avrdude: Sent: . [03] . [94]
avrdude: Recv: . [03] . [00] ! [21]
Vtarget : 3.3 V
avrdude: Sent: . [03] . [98]
avrdude: Recv: . [03] . [00] . [06]
SCK period : 8.00 us
avrdude: Sent: . [10] . [c8] d [64] . [19] [20] . [00] S [53] . [03] . [ac] S [53] . [00] . [00]
avrdude: Recv: . [10] . [00]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Sent: . [1d] . [04] . [04] . [00] 0 [30] . [00] . [00] . [00]
avrdude: Recv: . [1d] . [00] . [00] 0 [30] . [00] . [1e] . [00]
avrdude: Sent: . [1d] . [04] . [04] . [00] 0 [30] . [00] . [01] . [00]
avrdude: Recv: . [1d] . [00] . [00] 0 [30] . [00] . [95] . [00]
################avrdude: Sent: . [1d] . [04] . [04] . [00] 0 [30] . [00] . [02] . [00]
avrdude: Recv: . [1d] . [00] . [00] 0 [30] . [00] . [87] . [00]
################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587
avrdude: Sent: . [1d] . [04] . [04] . [00] . [a0] . [03] . [fc] . [00]
avrdude: Recv: . [1d] . [00] . [00] . [a0] . [03] . [ff] . [00]
avrdude: Sent: . [1d] . [04] . [04] . [00] . [a0] . [03] . [fd] . [00]
avrdude: Sent: . [1d] . [04] . [04] . [00] . [a0] . [03] . [fe] . [00]
avrdude: Sent: . [1d] . [04] . [04] . [00] . [a0] . [03] . [ff] . [00]
avrdude: erasing chip
avrdude: Sent: . [12] . [09] . [00] . [ac] . [80] . [f1] . [ff]
avrdude: Recv: . [12] . [00]
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | avrdude: Sent: . [1d] . [04] . [04] . [00] X [58] . [00] . [00] . [00]
avrdude: Recv: . [1d] . [00] . [00] X [58] . [00] . [ff] . [00]
################################################## | 100% 0.00s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | avrdude: Sent: . [1d] . [04] . [04] . [00] X [58] . [00] . [00] . [00]
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0xfe"
avrdude: writing efuse (1 bytes):
Writing | avrdude: Sent: . [1d] . [04] . [04] . [00] P [50] . [08] . [00] . [00]
avrdude: Recv: . [1d] . [00] . [00] P [50] . [08] . [ce] . [00]
avrdude: Sent: . [1d] . [04] . [04] . [00] . [ac] . [a4] . [00] . [0e]
avrdude: Recv: . [1d] . [00] . [00] . [ac] . [a4] . [00] . [00]
avrdude: Recv: . [1d] . [00] . [0e] P [50] . [08] . [ff] . [00]
avrdude: Recv: . [1d] . [00] . [00] P [50] . [08] . [ff] . [00]
***failed;
################################################## | 100% 0.06s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xfe:
avrdude: load data efuse data from input file 0xfe:
avrdude: input file 0xfe contains 1 bytes
avrdude: reading on-chip efuse data:
Reading | avrdude: Sent: . [1d] . [04] . [04] . [00] P [50] . [08] . [00] . [00]
avrdude: verification error, first mismatch at byte 0x0000
0xfe != 0xce
avrdude: verification error; content mismatch
avrdude: Sent: . [11] . [01] . [01]
avrdude: Recv: . [11] . [00]
avrdude done. Thank you.
I receive this on the original FIO v3 and my clone as well. Both boards are not recognized by the Arduino IDE.
Any hints what’s the problem and how I can solve them?
Thank you very much in advance,
Michael.
