I have recently started using OpenOCD ver. 0.1.0
And i am also getting “SIMILAR” error as you did.
It produces following dump in the console of the ECLIPSE.
Open On-Chip Debugger 0.1.0 (2009-01-21-21:15) Release
BUGS? Read http://svn.berlios.de/svnroot/repos/openocd/trunk/BUGS
$URL: https://kc8apf@svn.berlios.de/svnroot/r … /openocd.c $
500 kHz
500 kHz
Info : JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (Manufacturer: 0x23b, Part: 0xba00, Version: 0x3)
Info : JTAG Tap/device matched
Info : JTAG tap: stm32.bs tap/device found: 0x06414041 (Manufacturer: 0x020, Part: 0x6414, Version: 0x0)
Error: JTAG tap: stm32.bs got: 0x06414041 (mfg: 0x020, part: 0x6414, ver: 0x0)
Error: JTAG tap: stm32.bs expected 1 of 1: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Error: trying to validate configured JTAG chain anyway…
target state: halted
target halted due to debug-request, current mode: Handler HardFault
xPSR: 0x41000003 pc: 0x20000014
verify Capture-IR is disabled
Info : device id = 0x10016414
Error: SWJ-DP STICKY ERROR
Error: dcb_dhcsr 0x30003, nvic_shcsr 0x20000, nvic_cfsr 0x1, nvic_bfar 0xe000edf8
Warn : STM32 flash size failed, probe inaccurate - assuming 512k flash
Info : flash size = 512kbytes
Error: stm32x device protected
stm32x mass erase complete
Error: timed out while waiting for target halted
Error: error executing stm32x flash write algorithm
Error: flash writing failed with error code: 0xfffffc7a
Error: error writing to flash at address 0x08000000 at offset 0x00000000 (-902)
By the way, before i got this message, i downloaded program to READ PROTECT the Flash,
using the following code
if(FLASH_GetReadOutProtectionStatus() != SET)
FLASH_Unlock();//This MUST done first
FLASH_ReadOutProtection(ENABLE);
NVIC_GenerateSystemReset();
Did you get your problem solved?
if so, can you help me in getting this working again?
