i have set up an eclipse environment and use openOCD with the STM32L Discovery Board from ST. When i started to use const variables, openOCD hangs at flashing my program.
Before i used const variables i was able to use openOCD successfully. I think the failure is related to the const data section placed in flash.
Invoking: ARM Summon Linux GNU Print Size
arm-none-eabi-size --format=berkeley stm32l_test.elf
text data bss dec hex filename
1612 32 128 1772 6ec stm32l_test.elf
Finished building: stm32l_test.siz
Best regards
Garag
I am using openOCD with the following command line:
bin/openocd-0.6.1.exe -d 3 -l stm32l_test.log -f scripts/board/stm32ldiscovery.cfg
The content of the logfile is as follows:
Debug: 104 31 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu configure -work-area-phys 0x20000000 -work-area-size 0x3800 -work-area-backup 0
Debug: 105 31 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu configure -work-area-phys 0x20000000 -work-area-size 0x3800 -work-area-backup 0
Debug: 106 31 target.c:1620 target_free_all_working_areas_restore(): freeing all working areas
Debug: 107 31 target.c:1620 target_free_all_working_areas_restore(): freeing all working areas
Debug: 108 31 target.c:1620 target_free_all_working_areas_restore(): freeing all working areas
Debug: 109 31 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_flash bank stm32lx.flash stm32lx 0 0 0 0 stm32lx.cpu
Debug: 110 31 command.c:145 script_debug(): command - ocd_flash ocd_flash bank stm32lx.flash stm32lx 0 0 0 0 stm32lx.cpu
Debug: 112 31 tcl.c:781 handle_flash_bank_command(): ‘stm32lx’ driver usage field missing
Debug: 113 31 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_reset_config srst_only srst_nogate
Debug: 114 31 command.c:145 script_debug(): command - reset_config ocd_reset_config srst_only srst_nogate
User : 116 31 command.c:549 command_print(): srst_only separate srst_nogate srst_open_drain
Debug: 117 125 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_init
Debug: 118 125 command.c:145 script_debug(): command - init ocd_init
Debug: 120 125 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_target init
Debug: 121 125 command.c:145 script_debug(): command - ocd_target ocd_target init
Debug: 123 125 target.c:1183 handle_target_init_command(): Initializing targets…
Debug: 124 125 stm32_stlink.c:291 stm32_stlink_init_target(): stm32_stlink_init_target
Debug: 125 125 command.c:369 register_command_handler(): registering ‘ocd_target_request’…
Debug: 126 125 command.c:369 register_command_handler(): registering ‘ocd_trace’…
Debug: 127 125 command.c:369 register_command_handler(): registering ‘ocd_trace’…
Debug: 128 125 command.c:369 register_command_handler(): registering ‘ocd_fast_load_image’…
Debug: 129 125 command.c:369 register_command_handler(): registering ‘ocd_fast_load’…
Debug: 130 125 command.c:369 register_command_handler(): registering ‘ocd_profile’…
Debug: 131 125 command.c:369 register_command_handler(): registering ‘ocd_virt2phys’…
Debug: 132 125 command.c:369 register_command_handler(): registering ‘ocd_reg’…
Debug: 133 125 command.c:369 register_command_handler(): registering ‘ocd_poll’…
Debug: 134 125 command.c:369 register_command_handler(): registering ‘ocd_wait_halt’…
Debug: 135 125 command.c:369 register_command_handler(): registering ‘ocd_halt’…
Debug: 136 125 command.c:369 register_command_handler(): registering ‘ocd_resume’…
Debug: 137 125 command.c:369 register_command_handler(): registering ‘ocd_reset’…
Debug: 138 125 command.c:369 register_command_handler(): registering ‘ocd_soft_reset_halt’…
Debug: 139 125 command.c:369 register_command_handler(): registering ‘ocd_step’…
Debug: 140 125 command.c:369 register_command_handler(): registering ‘ocd_mdw’…
Debug: 141 125 command.c:369 register_command_handler(): registering ‘ocd_mdh’…
Debug: 142 125 command.c:369 register_command_handler(): registering ‘ocd_mdb’…
Debug: 143 125 command.c:369 register_command_handler(): registering ‘ocd_mww’…
Debug: 144 125 command.c:369 register_command_handler(): registering ‘ocd_mwh’…
Debug: 145 125 command.c:369 register_command_handler(): registering ‘ocd_mwb’…
Debug: 146 125 command.c:369 register_command_handler(): registering ‘ocd_bp’…
Debug: 147 125 command.c:369 register_command_handler(): registering ‘ocd_rbp’…
Debug: 148 125 command.c:369 register_command_handler(): registering ‘ocd_wp’…
Debug: 149 125 command.c:369 register_command_handler(): registering ‘ocd_rwp’…
Debug: 150 125 command.c:369 register_command_handler(): registering ‘ocd_load_image’…
Debug: 151 125 command.c:369 register_command_handler(): registering ‘ocd_dump_image’…
Debug: 152 125 command.c:369 register_command_handler(): registering ‘ocd_verify_image’…
Debug: 153 125 command.c:369 register_command_handler(): registering ‘ocd_test_image’…
Debug: 154 125 command.c:369 register_command_handler(): registering ‘ocd_reset_nag’…
Debug: 155 125 command.c:369 register_command_handler(): registering ‘ocd_ps’…
Debug: 156 125 stlink_interface.c:91 stlink_interface_init(): stlink_interface_init
Debug: 157 125 stlink_layout.c:88 stlink_layout_init(): stlink_layout_init
Debug: 158 125 core.c:1592 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 159 125 core.c:1595 adapter_khz_to_speed(): have interface set up
Debug: 160 125 stlink_interface.c:106 stlink_interface_speed(): stlink_interface_speed: ignore speed 1000
Debug: 161 125 core.c:1592 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 162 125 core.c:1595 adapter_khz_to_speed(): have interface set up
Info : 163 125 core.c:1399 adapter_init(): clock speed 1000 kHz
Debug: 164 125 openocd.c:132 handle_init_command(): Debug Adapter init complete
Debug: 165 125 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_transport init
Debug: 166 125 command.c:145 script_debug(): command - ocd_transport ocd_transport init
Debug: 168 125 transport.c:240 handle_transport_init(): handle_transport_init
Debug: 169 125 stlink_transport.c:140 stlink_transport_init(): stlink_transport_init
Debug: 170 125 stlink_transport.c:157 stlink_transport_init(): current transport stlink_swd
Debug: 171 125 stlink_interface.c:41 stlink_interface_open(): stlink_interface_open
Debug: 172 125 stlink_layout.c:43 stlink_layout_open(): stlink_layout_open
Debug: 173 125 stlink_usb.c:1152 stlink_usb_open(): stlink_usb_open
Debug: 174 125 stlink_usb.c:1167 stlink_usb_open(): transport: 1 vid: 0x0483 pid: 0x3748
Debug: 175 374 stlink_usb.c:422 stlink_usb_version(): STLINK v2 JTAG v15 API v2 SWIM v0 VID 0x0483 PID 0x3748
Debug: 176 374 stlink_usb.c:564 stlink_usb_init_mode(): MODE: 0x02
Debug: 177 374 stlink_usb.c:596 stlink_usb_init_mode(): MODE: 0x01
Debug: 178 374 stlink_usb.c:629 stlink_usb_init_mode(): MODE: 0x02
Debug: 179 374 stlink_interface.c:53 stlink_interface_init_target(): stlink_interface_init_target
Debug: 180 374 stlink_usb.c:656 stlink_usb_idcode(): IDCODE: 0x2BA01477
Debug: 181 374 openocd.c:145 handle_init_command(): Examining targets…
Debug: 182 374 target.c:1299 target_call_event_callbacks(): target event 21 (examine-start)
Debug: 183 374 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0xe000ed00 4 1
Debug: 184 374 target.c:1917 target_read_u32(): address: 0xe000ed00, value: 0x412fc230
Debug: 185 374 cortex_m.c:1815 cortex_m3_examine(): Cortex-M3 r2p0 processor detected
Debug: 186 374 cortex_m.c:1816 cortex_m3_examine(): cpuid: 0x412fc230
Debug: 187 374 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0xe0002000 4 1
Debug: 188 374 target.c:1917 target_read_u32(): address: 0xe0002000, value: 0x00000260
Debug: 189 374 cortex_m.c:1860 cortex_m3_examine(): FPB fpcr 0x260, numcode 6, numlit 2
Debug: 190 374 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0xe0001000 4 1
Debug: 191 374 target.c:1917 target_read_u32(): address: 0xe0001000, value: 0x40000000
Debug: 192 374 cortex_m.c:1772 cortex_m3_dwt_setup(): DWT dwtcr 0x40000000, comp 4, watch/trigger
Info : 193 374 cortex_m.c:1869 cortex_m3_examine(): stm32lx.cpu: hardware has 6 breakpoints, 4 watchpoints
Debug: 194 374 target.c:1299 target_call_event_callbacks(): target event 22 (examine-end)
Debug: 195 374 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_flash init
Debug: 196 374 command.c:145 script_debug(): command - ocd_flash ocd_flash init
Debug: 198 374 tcl.c:847 handle_flash_init_command(): Initializing flash devices…
Debug: 199 374 command.c:369 register_command_handler(): registering ‘ocd_flash’…
Debug: 200 374 command.c:369 register_command_handler(): registering ‘ocd_flash’…
Debug: 201 374 command.c:369 register_command_handler(): registering ‘ocd_flash’…
Debug: 202 374 command.c:369 register_command_handler(): registering ‘ocd_flash’…
Debug: 203 374 command.c:369 register_command_handler(): registering ‘ocd_flash’…
Debug: 204 374 command.c:369 register_command_handler(): registering ‘ocd_flash’…
Debug: 205 374 command.c:369 register_command_handler(): registering ‘ocd_flash’…
Debug: 206 374 command.c:369 register_command_handler(): registering ‘ocd_flash’…
Debug: 207 374 command.c:369 register_command_handler(): registering ‘ocd_flash’…
Debug: 208 374 command.c:369 register_command_handler(): registering ‘ocd_flash’…
Debug: 209 374 command.c:369 register_command_handler(): registering ‘ocd_flash’…
Debug: 210 374 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_mflash init
Debug: 211 374 command.c:145 script_debug(): command - ocd_mflash ocd_mflash init
Debug: 213 374 mflash.c:1379 handle_mflash_init_command(): Initializing mflash devices…
Debug: 214 374 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_nand init
Debug: 215 374 command.c:145 script_debug(): command - ocd_nand ocd_nand init
Debug: 217 374 tcl.c:497 handle_nand_init_command(): Initializing NAND devices…
Debug: 218 374 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_pld init
Debug: 219 374 command.c:145 script_debug(): command - ocd_pld ocd_pld init
Debug: 221 374 pld.c:207 handle_pld_init_command(): Initializing PLDs…
Info : 222 15116 server.c:83 add_connection(): accepting ‘gdb’ connection from 3333
Debug: 223 15116 breakpoints.c:359 breakpoint_clear_target_internal(): Delete all breakpoints for target: stm32lx.cpu
Debug: 224 15116 breakpoints.c:499 watchpoint_clear_target(): Delete all watchpoints for target: stm32lx.cpu
Debug: 225 15116 target.c:1299 target_call_event_callbacks(): target event 23 (gdb-attach)
Debug: 226 15116 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0xe0042000 4 1
Debug: 227 15116 target.c:1917 target_read_u32(): address: 0xe0042000, value: 0x10186416
Debug: 228 15116 stm32lx.c:476 stm32lx_probe(): device id = 0x10186416
Debug: 229 15116 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x1ff8004c 2 1
Debug: 230 15116 target.c:1941 target_read_u16(): address: 0x1ff8004c, value: 0x0080
Info : 231 15116 stm32lx.c:507 stm32lx_probe(): flash size = 128kbytes
Debug: 232 15116 gdb_server.c:821 gdb_new_connection(): New GDB Connection: 1, Target stm32lx.cpu, state: unknown
Debug: 233 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘qSupported:qRelocInsn+’
Debug: 234 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘QStartNoAckMode’
Warn : 235 15116 gdb_server.c:606 gdb_get_packet_inner(): acknowledgment received, but no packet pending
Debug: 236 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘Hg0’
Debug: 237 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘?’
User : 238 15116 gdb_server.c:128 gdb_last_signal(): undefined debug reason 6 - target needs reset
Debug: 239 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘Hc-1’
Debug: 240 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘qC’
Debug: 241 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘qAttached’
Debug: 242 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘qOffsets’
Debug: 243 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘g’
Debug: 244 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘qXfer:memory-map:read::0,fff’
Debug: 245 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘m0,4’
Debug: 246 15116 gdb_server.c:1200 gdb_read_memory_packet(): addr: 0x00000000, len: 0x00000004
Debug: 247 15116 target.c:1769 target_read_buffer(): reading buffer of 4 byte at 0x00000000
Debug: 248 15116 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x00000000 4 1
Debug: 249 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘qTStatus’
Debug: 250 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘qfThreadInfo’
Debug: 251 15116 gdb_server.c:2048 gdb_input_inner(): received packet: ‘qL1200000000000000000’
Debug: 252 15132 gdb_server.c:2048 gdb_input_inner(): received packet: ‘qRcmd,72657365742068616c74’
Debug: 253 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_reset halt
Debug: 254 15132 command.c:145 script_debug(): command - reset ocd_reset halt
Debug: 256 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_target names
Debug: 257 15132 command.c:145 script_debug(): command - ocd_target ocd_target names
Debug: 258 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu invoke-event reset-start
Debug: 259 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu invoke-event reset-start
Debug: 260 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag arp_init-reset
Debug: 261 15132 command.c:145 script_debug(): command - ocd_jtag ocd_jtag arp_init-reset
Debug: 263 15132 stlink_transport.c:37 stlink_transport_jtag_command(): stlink_transport_jtag_command
Debug: 264 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu cget -chain-position
Debug: 265 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu cget -chain-position
Debug: 266 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32lx.cpu
Debug: 267 15132 command.c:145 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32lx.cpu
Debug: 268 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu invoke-event examine-start
Debug: 269 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu invoke-event examine-start
Debug: 270 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu arp_examine
Debug: 271 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu arp_examine
Debug: 272 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu invoke-event examine-end
Debug: 273 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu invoke-event examine-end
Debug: 274 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu invoke-event reset-assert-pre
Debug: 275 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu invoke-event reset-assert-pre
Debug: 276 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu cget -chain-position
Debug: 277 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu cget -chain-position
Debug: 278 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32lx.cpu
Debug: 279 15132 command.c:145 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32lx.cpu
Debug: 280 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu arp_reset assert 1
Debug: 281 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu arp_reset assert 1
Debug: 282 15132 target.c:1620 target_free_all_working_areas_restore(): freeing all working areas
Debug: 283 15132 stm32_stlink.c:417 stm32_stlink_assert_reset(): stm32_stlink_assert_reset
Debug: 284 15132 stlink_interface.c:125 stlink_interface_execute_queue(): stlink_interface_execute_queue: ignored
Debug: 285 15132 core.c:715 jtag_add_reset(): SRST line asserted
Debug: 286 15132 core.c:743 jtag_add_reset(): TRST line released
Debug: 287 15132 core.c:323 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 288 15132 stlink_usb.c:788 stlink_usb_reset(): RESET: 0x00000080
Debug: 289 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu invoke-event reset-assert-post
Debug: 290 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu invoke-event reset-assert-post
Debug: 291 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu invoke-event reset-deassert-pre
Debug: 292 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu invoke-event reset-deassert-pre
Debug: 293 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu cget -chain-position
Debug: 294 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu cget -chain-position
Debug: 295 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32lx.cpu
Debug: 296 15132 command.c:145 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32lx.cpu
Debug: 297 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu arp_reset deassert 1
Debug: 298 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu arp_reset deassert 1
Debug: 299 15132 target.c:1620 target_free_all_working_areas_restore(): freeing all working areas
Debug: 300 15132 stm32_stlink.c:475 stm32_stlink_deassert_reset(): stm32_stlink_deassert_reset
Debug: 301 15132 stlink_interface.c:125 stlink_interface_execute_queue(): stlink_interface_execute_queue: ignored
Debug: 302 15132 core.c:719 jtag_add_reset(): SRST line released
Debug: 303 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu invoke-event reset-deassert-post
Debug: 304 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu invoke-event reset-deassert-post
Debug: 305 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu cget -chain-position
Debug: 306 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu cget -chain-position
Debug: 307 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32lx.cpu
Debug: 308 15132 command.c:145 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32lx.cpu
Debug: 309 15132 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu arp_waitstate halted 1000
Debug: 310 15132 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu arp_waitstate halted 1000
Debug: 311 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 312 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 0 value 0x0
Debug: 313 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 314 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 1 value 0x0
Debug: 315 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 316 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 2 value 0x0
Debug: 317 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 318 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 3 value 0x0
Debug: 319 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 320 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 4 value 0x0
Debug: 321 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 322 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 5 value 0x0
Debug: 323 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 324 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 6 value 0x0
Debug: 325 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 326 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 7 value 0x0
Debug: 327 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 328 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 8 value 0x0
Debug: 329 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 330 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 9 value 0x0
Debug: 331 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 332 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 10 value 0x0
Debug: 333 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 334 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 11 value 0x0
Debug: 335 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 336 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 12 value 0x0
Debug: 337 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 338 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 13 value 0x0
Debug: 339 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 340 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 14 value 0xffffffff
Debug: 341 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 342 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 15 value 0x0
Debug: 343 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 344 15132 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 16 value 0x0
Debug: 345 15132 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 346 15147 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 17 value 0x0
Debug: 347 15147 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 348 15147 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 18 value 0x0
Debug: 349 15147 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 350 15147 stm32_stlink.c:136 stm32_stlink_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 351 15147 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 352 15147 stm32_stlink.c:136 stm32_stlink_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 353 15147 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 354 15147 stm32_stlink.c:136 stm32_stlink_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 355 15147 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 356 15147 stm32_stlink.c:136 stm32_stlink_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 357 15147 stm32_stlink.c:372 stlink_debug_entry(): entered debug state in core mode: Thread at PC 0x00000000, target->state: halted
Debug: 358 15147 target.c:1299 target_call_event_callbacks(): target event 0 (gdb-halt)
Debug: 359 15147 target.c:1299 target_call_event_callbacks(): target event 1 (halted)
User : 360 15147 target.c:1672 target_arch_state(): target state: halted
User : 361 15147 armv7m.c:517 armv7m_arch_state(): target halted due to debug-request, current mode: Thread
xPSR: 00000000 pc: 00000000 msp: 00000000
Debug: 362 15147 target.c:1299 target_call_event_callbacks(): target event 6 (gdb-end)
Debug: 363 15147 stm32_stlink.c:404 stm32_stlink_poll(): halted: PC: 0x00000000
Debug: 364 15147 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu curstate
Debug: 365 15147 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu curstate
Debug: 366 15147 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32lx.cpu invoke-event reset-end
Debug: 367 15147 command.c:145 script_debug(): command - ocd_stm32lx.cpu ocd_stm32lx.cpu invoke-event reset-end
Debug: 368 15147 gdb_server.c:2048 gdb_input_inner(): received packet: ‘vFlashErase:08000000,00001000’
Debug: 369 15147 target.c:1299 target_call_event_callbacks(): target event 25 (gdb-flash-erase-start)
Debug: 370 15147 stlink_interface.c:125 stlink_interface_execute_queue(): stlink_interface_execute_queue: ignored
Debug: 371 15147 target.c:1983 target_write_u32(): address: 0x40023c0c, value: 0x89abcdef
Debug: 372 15147 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c0c 4 1
Debug: 373 15147 target.c:1983 target_write_u32(): address: 0x40023c0c, value: 0x02030405
Debug: 374 15147 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c0c 4 1
Debug: 375 15147 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c04 4 1
Debug: 376 15147 target.c:1917 target_read_u32(): address: 0x40023c04, value: 0x00000006
Debug: 377 15147 target.c:1983 target_write_u32(): address: 0x40023c10, value: 0x8c9daebf
Debug: 378 15147 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c10 4 1
Debug: 379 15147 target.c:1983 target_write_u32(): address: 0x40023c10, value: 0x13141516
Debug: 380 15147 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c10 4 1
Debug: 381 15147 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c04 4 1
Debug: 382 15147 target.c:1917 target_read_u32(): address: 0x40023c04, value: 0x00000004
Debug: 383 15147 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 384 15147 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 385 15147 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 386 15147 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000c
Debug: 387 15147 target.c:1983 target_write_u32(): address: 0x08000000, value: 0x00000000
Debug: 388 15147 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000000 4 1
Debug: 389 15147 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 390 15147 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x00000009
Debug: 391 15163 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 392 15163 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x00000009
Debug: 393 15179 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 394 15179 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 395 15179 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 396 15179 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 397 15179 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 398 15179 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 399 15179 target.c:1983 target_write_u32(): address: 0x08000100, value: 0x00000000
Debug: 400 15179 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000100 4 1
Debug: 401 15179 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 402 15179 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 403 15194 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 404 15194 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 405 15194 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 406 15194 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 407 15194 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 408 15194 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 409 15194 target.c:1983 target_write_u32(): address: 0x08000200, value: 0x00000000
Debug: 410 15194 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000200 4 1
Debug: 411 15194 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 412 15194 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 413 15210 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 414 15210 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 415 15210 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 416 15210 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 417 15210 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 418 15210 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 419 15210 target.c:1983 target_write_u32(): address: 0x08000300, value: 0x00000000
Debug: 420 15210 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000300 4 1
Debug: 421 15210 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 422 15210 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 423 15225 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 424 15225 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 425 15225 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 426 15225 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 427 15225 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 428 15225 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 429 15225 target.c:1983 target_write_u32(): address: 0x08000400, value: 0x00000000
Debug: 430 15225 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000400 4 1
Debug: 431 15225 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 432 15225 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 433 15241 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 434 15241 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 435 15241 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 436 15241 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 437 15241 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 438 15241 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 439 15241 target.c:1983 target_write_u32(): address: 0x08000500, value: 0x00000000
Debug: 440 15241 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000500 4 1
Debug: 441 15241 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 442 15241 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 443 15257 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 444 15257 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 445 15257 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 446 15257 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 447 15257 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 448 15257 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 449 15257 target.c:1983 target_write_u32(): address: 0x08000600, value: 0x00000000
Debug: 450 15257 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000600 4 1
Debug: 451 15257 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 452 15257 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 453 15272 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 454 15272 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 455 15272 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 456 15272 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 457 15272 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 458 15272 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 459 15272 target.c:1983 target_write_u32(): address: 0x08000700, value: 0x00000000
Debug: 460 15272 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000700 4 1
Debug: 461 15272 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 462 15272 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 463 15288 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 464 15288 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 465 15288 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 466 15288 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 467 15288 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 468 15288 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 469 15288 target.c:1983 target_write_u32(): address: 0x08000800, value: 0x00000000
Debug: 470 15288 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000800 4 1
Debug: 471 15288 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 472 15288 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 473 15303 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 474 15303 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 475 15303 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 476 15303 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 477 15303 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 478 15303 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 479 15303 target.c:1983 target_write_u32(): address: 0x08000900, value: 0x00000000
Debug: 480 15303 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000900 4 1
Debug: 481 15303 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 482 15303 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 483 15319 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 484 15319 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 485 15319 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 486 15319 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 487 15319 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 488 15319 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 489 15319 target.c:1983 target_write_u32(): address: 0x08000a00, value: 0x00000000
Debug: 490 15319 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000a00 4 1
Debug: 491 15319 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 492 15319 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 493 15335 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 494 15335 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 495 15335 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 496 15335 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 497 15335 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 498 15335 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 499 15335 target.c:1983 target_write_u32(): address: 0x08000b00, value: 0x00000000
Debug: 500 15335 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000b00 4 1
Debug: 501 15335 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 502 15335 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 503 15350 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 504 15350 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 505 15350 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 506 15350 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 507 15350 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 508 15350 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 509 15350 target.c:1983 target_write_u32(): address: 0x08000c00, value: 0x00000000
Debug: 510 15350 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000c00 4 1
Debug: 511 15350 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 512 15350 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 513 15366 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 514 15366 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 515 15366 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 516 15366 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 517 15366 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 518 15366 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 519 15366 target.c:1983 target_write_u32(): address: 0x08000d00, value: 0x00000000
Debug: 520 15366 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000d00 4 1
Debug: 521 15366 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 522 15366 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 523 15381 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 524 15381 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 525 15381 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 526 15381 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 527 15381 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 528 15381 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 529 15381 target.c:1983 target_write_u32(): address: 0x08000e00, value: 0x00000000
Debug: 530 15381 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000e00 4 1
Debug: 531 15381 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 532 15381 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 533 15397 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 534 15397 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 535 15397 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000208
Debug: 536 15397 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 537 15397 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 538 15397 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 539 15397 target.c:1983 target_write_u32(): address: 0x08000f00, value: 0x00000000
Debug: 540 15397 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x08000f00 4 1
Debug: 541 15397 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 542 15397 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000b
Debug: 543 15413 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c18 4 1
Debug: 544 15413 target.c:1917 target_read_u32(): address: 0x40023c18, value: 0x0000000e
Debug: 545 15413 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c04 4 1
Debug: 546 15413 target.c:1917 target_read_u32(): address: 0x40023c04, value: 0x0000020c
Debug: 547 15413 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x0000020e
Debug: 548 15413 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 549 15413 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c04 4 1
Debug: 550 15413 target.c:1917 target_read_u32(): address: 0x40023c04, value: 0x0000020e
Debug: 551 15413 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x0000020f
Debug: 552 15413 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 553 15413 target.c:1299 target_call_event_callbacks(): target event 26 (gdb-flash-erase-end)
Debug: 554 15413 gdb_server.c:2048 gdb_input_inner(): received packet: ‘vFlashWrite:8000000:’
Debug: 555 15413 gdb_server.c:2048 gdb_input_inner(): received packet: ‘vFlashWrite:800010c:€´…°’
Debug: 556 15413 gdb_server.c:2048 gdb_input_inner(): received packet: ‘vFlashWrite:800064c:’
Debug: 557 15413 gdb_server.c:2048 gdb_input_inner(): received packet: ‘vFlashDone’
Debug: 558 15413 target.c:1299 target_call_event_callbacks(): target event 27 (gdb-flash-write-start)
Debug: 559 15413 core.c:703 flash_write_unlock(): image_read_section: section = 0, t_section_num = 0, section_offset = 0, buffer_size = 0, size_read = 1644
Debug: 560 15413 target.c:1470 target_alloc_working_area_try(): MMU disabled, using physical address for working memory 0x20000000
Debug: 561 15413 target.c:1523 target_alloc_working_area_try(): allocated new working area of 20 bytes at address 0x20000000
Debug: 562 15413 target.c:1386 print_wa_layout(): * 0x20000000-0x20000013 (20 bytes)
Debug: 563 15413 target.c:1386 print_wa_layout(): 0x20000014-0x200037ff (14316 bytes)
Debug: 564 15413 target.c:1688 target_write_buffer(): writing buffer of 20 byte at 0x20000000
Debug: 565 15413 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x20000000 4 5
Debug: 566 15413 target.c:1523 target_alloc_working_area_try(): allocated new working area of 13312 bytes at address 0x20000014
Debug: 567 15413 target.c:1386 print_wa_layout(): * 0x20000000-0x20000013 (20 bytes)
Debug: 568 15413 target.c:1386 print_wa_layout(): * 0x20000014-0x20003413 (13312 bytes)
Debug: 569 15413 target.c:1386 print_wa_layout(): 0x20003414-0x200037ff (1004 bytes)
Debug: 570 15413 stm32lx.c:299 stm32lx_write_half_pages(): allocated working area for data (3400 bytes)
Debug: 571 15413 target.c:1983 target_write_u32(): address: 0x40023c0c, value: 0x89abcdef
Debug: 572 15413 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c0c 4 1
Debug: 573 15413 target.c:1983 target_write_u32(): address: 0x40023c0c, value: 0x02030405
Debug: 574 15413 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c0c 4 1
Debug: 575 15413 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c04 4 1
Debug: 576 15413 target.c:1917 target_read_u32(): address: 0x40023c04, value: 0x00000006
Debug: 577 15413 target.c:1983 target_write_u32(): address: 0x40023c10, value: 0x8c9daebf
Debug: 578 15413 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c10 4 1
Debug: 579 15413 target.c:1983 target_write_u32(): address: 0x40023c10, value: 0x13141516
Debug: 580 15413 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c10 4 1
Debug: 581 15413 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c04 4 1
Debug: 582 15413 target.c:1917 target_read_u32(): address: 0x40023c04, value: 0x00000004
Debug: 583 15413 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c04 4 1
Debug: 584 15413 target.c:1917 target_read_u32(): address: 0x40023c04, value: 0x00000004
Debug: 585 15413 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x00000404
Debug: 586 15413 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 587 15413 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x40023c04 4 1
Debug: 588 15413 target.c:1917 target_read_u32(): address: 0x40023c04, value: 0x00000404
Debug: 589 15413 target.c:1983 target_write_u32(): address: 0x40023c04, value: 0x0000040c
Debug: 590 15413 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x40023c04 4 1
Debug: 591 15413 target.c:1688 target_write_buffer(): writing buffer of 1536 byte at 0x20000014
Debug: 592 15413 stm32_stlink.c:716 stm32_stlink_write_memory(): stm32_stlink_write_memory 0x20000014 4 384
Debug: 593 15459 target.c:1299 target_call_event_callbacks(): target event 3 (resume-start)
Debug: 594 15459 stm32_stlink.c:538 stm32_stlink_resume(): stm32_stlink_resume 0 0x20000000 1 1
Debug: 595 15459 armv7m.c:144 armv7m_restore_context():
Debug: 596 15459 stm32_stlink.c:155 stm32_stlink_store_core_reg_u32(): stm32_stlink_store_core_reg_u32
Debug: 597 15459 stm32_stlink.c:185 stm32_stlink_store_core_reg_u32(): write core reg 15 value 0x20000000
Debug: 598 15459 armv7m.c:252 armv7m_write_core_reg(): write core reg 15 value 0x20000000
Debug: 599 15459 stm32_stlink.c:155 stm32_stlink_store_core_reg_u32(): stm32_stlink_store_core_reg_u32
Debug: 600 15459 stm32_stlink.c:185 stm32_stlink_store_core_reg_u32(): write core reg 4 value 0x820050
Debug: 601 15459 armv7m.c:252 armv7m_write_core_reg(): write core reg 4 value 0x820050
Debug: 602 15459 stm32_stlink.c:155 stm32_stlink_store_core_reg_u32(): stm32_stlink_store_core_reg_u32
Debug: 603 15459 stm32_stlink.c:185 stm32_stlink_store_core_reg_u32(): write core reg 3 value 0x820080
Debug: 604 15459 armv7m.c:252 armv7m_write_core_reg(): write core reg 3 value 0x820080
Debug: 605 15459 stm32_stlink.c:155 stm32_stlink_store_core_reg_u32(): stm32_stlink_store_core_reg_u32
Debug: 606 15459 stm32_stlink.c:185 stm32_stlink_store_core_reg_u32(): write core reg 2 value 0x180
Debug: 607 15459 armv7m.c:252 armv7m_write_core_reg(): write core reg 2 value 0x180
Debug: 608 15459 stm32_stlink.c:155 stm32_stlink_store_core_reg_u32(): stm32_stlink_store_core_reg_u32
Debug: 609 15459 stm32_stlink.c:185 stm32_stlink_store_core_reg_u32(): write core reg 1 value 0x20000014
Debug: 610 15459 armv7m.c:252 armv7m_write_core_reg(): write core reg 1 value 0x20000014
Debug: 611 15459 stm32_stlink.c:155 stm32_stlink_store_core_reg_u32(): stm32_stlink_store_core_reg_u32
Debug: 612 15459 stm32_stlink.c:185 stm32_stlink_store_core_reg_u32(): write core reg 0 value 0x8000000
Debug: 613 15459 armv7m.c:252 armv7m_write_core_reg(): write core reg 0 value 0x8000000
Debug: 614 15459 target.c:1299 target_call_event_callbacks(): target event 2 (resumed)
Debug: 615 15459 target.c:1299 target_call_event_callbacks(): target event 4 (resume-end)
Debug: 616 15459 target.c:2449 target_wait_state(): waiting for target halted…
Error: 655 35474 target.c:2457 target_wait_state(): timed out while waiting for target halted
Debug: 656 35474 stm32_stlink.c:506 stm32_stlink_halt(): stm32_stlink_halt
Debug: 657 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 658 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 0 value 0x8000000
Debug: 659 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 660 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 1 value 0x20000014
Debug: 661 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 662 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 2 value 0x180
Debug: 663 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 664 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 3 value 0x820080
Debug: 665 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 666 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 4 value 0x820050
Debug: 667 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 668 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 5 value 0x0
Debug: 669 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 670 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 6 value 0x0
Debug: 671 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 672 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 7 value 0x0
Debug: 673 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 674 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 8 value 0x0
Debug: 675 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 676 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 9 value 0x0
Debug: 677 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 678 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 10 value 0x0
Debug: 679 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 680 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 11 value 0x0
Debug: 681 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 682 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 12 value 0x0
Debug: 683 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 684 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 13 value 0xffffffe0
Debug: 685 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 686 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 687 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 688 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 15 value 0x0
Debug: 689 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 690 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 16 value 0x3
Debug: 691 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 692 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 17 value 0xffffffe0
Debug: 693 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 694 35474 stm32_stlink.c:71 stm32_stlink_load_core_reg_u32(): load from core reg 18 value 0x0
Debug: 695 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 696 35474 stm32_stlink.c:136 stm32_stlink_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 697 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 698 35474 stm32_stlink.c:136 stm32_stlink_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 699 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 700 35474 stm32_stlink.c:136 stm32_stlink_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 701 35474 stm32_stlink.c:56 stm32_stlink_load_core_reg_u32(): stm32_stlink_load_core_reg_u32
Debug: 702 35474 stm32_stlink.c:136 stm32_stlink_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 703 35474 stm32_stlink.c:372 stlink_debug_entry(): entered debug state in core mode: Handler at PC 0x00000000, target->state: halted
Debug: 704 35474 target.c:1299 target_call_event_callbacks(): target event 0 (gdb-halt)
Debug: 705 35474 target.c:1299 target_call_event_callbacks(): target event 1 (halted)
User : 706 35474 target.c:1672 target_arch_state(): target state: halted
User : 707 35474 armv7m.c:517 armv7m_arch_state(): target halted due to debug-request, current mode: Handler HardFault
xPSR: 0x00000003 pc: 00000000 msp: 0xffffffe0
Debug: 708 35474 target.c:1299 target_call_event_callbacks(): target event 6 (gdb-end)
Debug: 709 35474 stm32_stlink.c:404 stm32_stlink_poll(): halted: PC: 0x00000000
Debug: 710 35474 target.c:1592 target_free_working_area_restore(): freed 13312 bytes of working area at address 0x20000014
Debug: 711 35474 target.c:1386 print_wa_layout(): * 0x20000000-0x20000013 (20 bytes)
Debug: 712 35474 target.c:1386 print_wa_layout(): 0x20000014-0x200037ff (14316 bytes)
Debug: 713 35474 target.c:1592 target_free_working_area_restore(): freed 20 bytes of working area at address 0x20000000
Debug: 714 35474 target.c:1386 print_wa_layout(): 0x20000000-0x200037ff (14336 bytes)
Error: 715 35474 core.c:93 flash_driver_write(): error writing to flash at address 0x08000000 at offset 0x00000000
Debug: 716 35474 target.c:1299 target_call_event_callbacks(): target event 28 (gdb-flash-write-end)
Debug: 717 35474 gdb_server.c:2048 gdb_input_inner(): received packet: ‘qL1200000000000000000’
Debug: 718 35474 gdb_server.c:2048 gdb_input_inner(): received packet: ‘m0,4’
Debug: 719 35474 gdb_server.c:1200 gdb_read_memory_packet(): addr: 0x00000000, len: 0x00000004
Debug: 720 35474 target.c:1769 target_read_buffer(): reading buffer of 4 byte at 0x00000000
Debug: 721 35474 stm32_stlink.c:668 stm32_stlink_read_memory(): stm32_stlink_read_memory 0x00000000 4 1
Debug: 722 35505 gdb_server.c:847 gdb_connection_closed(): GDB Close, Target: stm32lx.cpu, state: halted, gdb_actual_connections=0
Debug: 723 35505 target.c:1299 target_call_event_callbacks(): target event 6 (gdb-end)
Debug: 724 35505 target.c:1299 target_call_event_callbacks(): target event 24 (gdb-detach)
Info : 725 35505 server.c:472 server_loop(): dropped ‘gdb’ connection
