Hi, I am considering a project to add a sensor to the goal boxes of my foosball table and wanted to ask for a little advice from this community.
My idea is to have some kind of sensor behind a general padding (1/4" cork or foam) which will do two things: deaden the goal sound a little and generalize/absorb the shock from a ball hitting the back wall of a foosball goal.
Wondering what sensor type might work best to capture vibration like this, but not react to the movement of the table?
Or would there be a better sensor approach someone could offer (especially for a case where a ball just drops in the goal and doesn’t slam the back wall).
I was hoping to capture the goals with an arduino and count scores, play sounds, etc.
haukeg:
I think the above rules out a vibe/shock sensor on the back wall. Can you mod the 'chamber' so that the ball drops through a just > ball-sized hole before it gets to where you remove it ? If so then a micro-switch or IR proximity sensor would detect a goal, albeit perhaps a few 0.1s after the fact.
haukeg:
Why not have the ball break a light beam as it moves into the goal. The break could be detected by the Arduino, and vibration shouldn't affect it.
