FreePCB with SMT parts
Has anyone here submitted a board to BatchPCB designed with FreePCB that used SMT parts? I’ve previously used FreePCB to make a thru-hole board with BatchPCB without issues but my SMT board got rejected when they tried to panelize it. I’ve traced the problem to the fact that FreePCB makes SMT pads using a polygon fill in the Gerber, which apparently the software that BatchPCB uses doesn’t like (I’ve found talk on here of other problems which seem related to this). Anyway, just wondering if anyone has found a way around this problem. As far as I can tell the Gerber itself is correct (and it shows correctly in several Gerber viewers).
