FreeSOC2 USB-UART Bridge
Hello Sparkfun,
I would like to know if you have a method to configure the UART-USB FreeSoC2 bridge on PSoC creator since I could not configure it on the conventional way. I just have trash on PuTTY.
In the following picture, you can see the context. In the same way, the project is attached.
Looking forward for your kindly response.
Kind regards,
George
UART_Test.zip (5.8 KB)
Hi George,
We do not have a specific project in the PSoC Creator for making a USB-UART bridge but there should be an example project in that creator for the USBUART component. It’s hard to tell from your image if that is what you are already attempting to use, so if you are, let me know and we can try and troubleshoot a bit further to figure out what is going wrong here. Another possible source of the issue may be your baud rate. Have you tried playing with different baud rates and had the same issue?
I hope this helps!
