I have just down load the latest OpenOCD version (546) and found
it working much better and faster than the previous version I was using.
Thanks for the hard work.
I have been struggling with reliability problems for the last 4 months, and finally cured it yesterday.
The solution was to add a 100pF capacitor to the TCK line at the connector
where the signal came on to the board. The signal was being driven by an Amontec JTAG Key.
I had looked at these signals on many occasions without success and as they looked clean I had not though anything was needed, and actually was blaming the software (Sorry).
I looked again yesterday as a new board was giving me a lot of grief. I used an old scope with larger capacitive load and the problem went away just like that.
I do not have any similar problems with other chips I debug and can only assume that the silicon process used for the ixp432 is much faster that most and it was capable of seeing very small glitches caused by noise.
I have now been running the board for 2 days without problems, and it feels great.
Any way I hope this note may help other people.
Dave
PS
The TCK signal also passes through a 100R series resistor, then to the 100pF capacitor.
