gcc and fiq
Does anyone know the attribute in gcc that makes an interrupt routine use the fiq stack?
Thanks.
Hey,
guess this is what you’re looking for:
attribute ((interrupt(“FIQ”)));
Not sure what you mean by “that makes an interrupt routine use the fiq stack?” though. In FIQ mode, r13 is a banked register - therefor if the code executes in FIQ mode, it will use whatever stack is pointed at by r13_fiq.
Regards,
Dominic
