General Arduino Question
Can I blow away the bootloader on an Arduino board and use the micro with a JTAG ICE and AVRStudio? I need a carrier/proto board for the ATmega1280 and the ArduinoMEGA looks good.
-Rocko
Definitely. That’s no problem at all.
lehmanna:
Cool. Thanks for the reply.
I’ve since found that not ALL the pins are routed on the ArduinoMega so…I’ll probably go with something else. At least now I know the Arduino variants are an option.
Thanks again,
-Rocko
Silly question, but you asked for it :): What do you need the other pins for? Most if not all of the important ones have been made accessible… Just curious…
lehmanna:
A parallel data bus with another ATmega1280 and an expansion port.
A perfect use for the not so important I/O.
-Rocko
Well, thanks for the enlightenment!
You could get Seeedstudio’s Mega clone - it breaks out the missing pins.
Cheaper too.
http://www.seeedstudio.com/depot/seeedu … p-438.html
I decided to go this route:
http://www.mikroe.com/en/tools/mcu_cards/avr/bigavr/
Gives me all pins. I don’t need the extras (usb interface, regulator, ect…).
The Seeedstudio Mega was runner up.
-Rocko
IMO: don’t buy Mikro E’s software. To say it’s buggy is an understatement.
I have one of these low-end JTAGs. Works fine w/Studio
http://www.nkcelectronics.com/avr-jtag- … r-kit.html
I think NKC is a SFE partner
stevech:
Thanks for the heads up. I’ll be using Atmels JTAG ICE and ISSP with AVRStudio. This particular project requires that I use the Codevision compiler.
-Rocko
