GITHUB over ARTEMIS REDBOARD BSP
The main BSP I found on SparkFun/SparkFun_Apollo3_AmbiqSuite_BSPs is Edge and Edge2 sheets. Does one of those work with the Artemis Redboard with AmbiqSuite?
Much obliged!
Huh - I’m not sure what you’re seeing but that repo also includes all our other BSPs
Here is the one for the RedBoard Artemis: https://github.com/sparkfun/SparkFun_Ap … rd_artemis
Here is the AmbiqSuite SDK but on GitHub and with our BSPs already included: https://github.com/sparkfun/AmbiqSuiteSDK
Steps to reproduce
Install Arduino
Add SparkFun boards to Arduino as per instillation instructions.
Select Board: SparkFun RedBoard Artemis Nano
Select Bootloader: SparkFun Variable Bootloader
Select SVL Baud Rate: 921600
Select port: Appropriate Port for Machine
Create Sketch:
