GM862 50-Pin Breakout wiring to RS232
Hi All
I have GM862-GPS and GM862 50-Pin Breakout, I could not connect them to Hyper terminal to test at command for sending SMS , I have tried everything I found in Google with negative result ;(,
So can I get help in wiring GM862 50-Pin Breakout with rs232 … ?(
http://www.sparkfun.com/datasheets/Cell … sional.pdf
While I don’t have this breakout board, I have used that module before and I know it relies on MUX to handle multiple devices on one port. You might want to check if +CMUX has been enabled. That would cause whatever port it is enabled on to be unreadable by simply connecting to it with a terminal program. You would need to use the telit serial port multiplexer software to read/write from it properly, or simply disable it.
thanks blambi
can somebody provide me with the schematic diagram ??
