I am using a GM862 PCS eval board. It does everything I need. If my company wanted to use this in a product, we would have to lay out a new board, design a box, and get it FCC approved. Its an expensive and tedius process.
I saw Round Solutions has one that is already in a box, but there isn’t much info on its FCC approval. Does anyone know about a simple GPRS terminal that is already FCC approved? Our only requirement is a serial port, preferable a standard 9 pin connector.
I have played with a Telular terminal, but it is overkill and a bit expensive as well. I already have some experience with the GM862 and there must be someone that makes a FCC approved terminal out of this module.
