I just want to know what are the diffrences between these two modules. I have just read the description of the 2 and I don’t see any real differences.
Netsupra
Sorry for my bad english, I’m french ![]()
Netsupra
The GM862-GPS mounts to a pcb via a connector soldered to the PCB.
The GE863 needs to be soldered to the PCB it mounts on.
Feature wise, the GM862-GPS has a python interpreter and internal sim card socket. The GE863 does not.
Cheers,
–David Carne
Ok, so how to mount the GM863 on the PCB ? I didn’t found any breakboard for it…
The GE863 is brand new… the breakout is still in design.
Cheers,
–David Carne
I’m pretty sure the GE863 has got Python, and it also has a few extra pins on it as well (or is that the 864…) The big difference is mounting style.
Does anybody knows some company which selling adapted pcb boards for GM862-GPS?
Pranas
pranas.slezas@infoside.lt
GM862-GPS is better for begining, but GE863-GPS cost less.
GM862-GPS has sim card reader inside so you will have less probles with hardware. Also GM862-GPS is better for reuse. For example if you mount GE863-GPS on the board so can not take it out. Also with GM862-GPS you can do smaller solution. GE863-GPS bga is easy for solrering no smd 50 connector which soldering is not easy ![]()
Regards,
Pranas
