i want to switch between 2 different states on 2 I/O Pins at the same time. For examble P0.0 is high an P0.1 is low - so i want P0.0 to low and P.1 to high with one instruction.
In C-Code i have to use IOCLR and IOSET to switch the pins. Is there a possibility to do this with only one instruction?
In the datasheet I found the IOPIN instruction in the GPIO section. It is signed as ReadOnly. But if i write: IOPIN ^= 0x3, the PINS will switch to the states at the same time. But normally (like it is discribed in the datasheet) it shouldn’t work. So does anyone know a better solution for my problem or is the datasheet not correct and the IOPIN instruction is for reading and writing?
