I hook in, in this topic because it seems to be that I have the same problem. In another topic I tried to connect to a website but it failed. In this forum I found other AT commands to connect with a server I tried that also. First i will show you my at commands.
Local echo on so I can see my http requests send to the website
at+cpin=0634
at+cpin=0634
OK
AT#USERID="tmobile"
AT#USERID="tmobile"
OK
AT#PASSW="tmobile"
AT#PASSW="tmobile"
OK
AT+CGDCONT=1,"IP","internet","0.0.0.0",0,0
OK
AT#SKTSAV
AT#SKTSAV
OK
AT#GPRS=1
AT#GPRS=1
+IP: 95.98.170.231
OK
AT#SD=1,0,80,"www.telit.com",0,0
CONNECT
GET / HTTP/1.1
Host: www.telit.com
NO CARRIER
Follower mentioned that it will work without at#gprs=1.
I tried that also:
at+cpin=0634
at+cpin=0634
OK
AT#USERID="tmobile"
AT#USERID="tmobile"
OK
AT#PASSW="tmobile"
AT#PASSW="tmobile"
OK
OK
AT#SKTSAV
AT#SKTSAV
OK
ERROR
That isn’t working.
For a extra check I tried with a telnet session on port 80 of the http://www.telit.com and that is working fine with the following commands
GET / HTTP/1.1
Host: www.telit.com
Also I tried AT+CGATT? and is returning 1
Command AT#SERVINFO is returning.
#SERVINFO: 998,-51,“Ben NL”,“20416”,64,0172,00,1,“I”,00,6
So gprs is supported.
I really don’t know what I can do more. I hope somebody here can tel me.
