The schematic shows the ZED I2C address set to 0x42 on this board. Is there any way to change that? I know this sounds stupid, but the GPS-22560 uses the same address for the ZED, and I’m using both in the system.
I think you should be able to change the default I2c address in U-center via the ports menu.
Hey John,
Thanks for responding. Got it. Much appreciated.
D
Glad to hear that.
Happy hacking.
Should be CFG-I2C-ADDRESS, notionally the 0x84 7-bit left aligned 0x42 address referenced elsewhere, depending on platform. Change in uCenter Classic via Generation 9 Configuration view.
