dear all,
I am new to this and don’t have much knowledge about electronics so any help will be highly appreciated!!
Project I want to build: a GPS sensor that records Glide ratio/dive angle, Horizontal speed Speed (up to 300 Kmh, more is fine), Vertical speed, Elevation up to 6000m more would be fine, GPS Accuracy about 1 m (less would be better)
Velocity: 0.1 m/s
being able to extract info to a 3d google map
connected to a micro sd card logger and a small battery that would give it at least 8 hours life
size: as small as possible to use it on a glider-motorcycle-boat and position it on the helmet
any suggestions on sensors or any part
thank you in advance
Alex
