Gps/gnss
I am looking for the most accurate system to set 100 fence posts on a curved road with a uneven decline in elevation. the posts are 108 inches apart. I would use the position to auger
a 12 inch diameter hole then I would place the 4 inch square post in the hole with the “SparkfunPNT RTK Facet mosaic” ?? mounted to the top of the fence post to the final position
in longitude and latitude and elevation. And the final step would be to add concrete to lock in the fence post.
Thank You
Tony C.
That sounds like a viable plan…the Facet Mosaic will perform will in this scenario
Do you have a specific question about it?
